AutoCAD Land Desktop (Read Only)
Image not displaying correctly
7 REPLIES 7
Message 1 of 8
remmnate
398 Views, 7 Replies
I am using land desktop 3 and when i try to insert air photos via map>image>insert they come into the drawing really wierd. See attachment. Any clues would be greatly appreciated.
7 REPLIES 7
Message 2 of 8
in reply to: remmnate
What type of file?
wrote in message news:5595749@discussion.autodesk.com...
Message 3 of 8
remmnate
Sorry.....I bet that would be helpful!! It is a .tiff file. I am thinking it some sort of driver or file association problem. The only program that will display it correctly is internet explorer with the quicktime plugin and or photoshop........
Here is a link to the files that I am downloading. Maybe someone else can try one and see if it works for them.
http://archive.casil.ucdavis.edu/casil/remote_sensing/doq/doqq-archive/33116/ Message was edited by: remmnate
Message 4 of 8
Perhaps it is a proprietary tif format that LDT3 isn't licensed to use?
If you can open it in a photo editor, save it to a new name in a different
format. Insert the new image in, move, rotate, scale as need to fit the bad
image. Remove the bad image.
JohnM
wrote in message news:5595873@discussion.autodesk.com...
Message 5 of 8
OK. The story is: I get the same results in LDT2006. It comes in fine in
LDT2008. That tells me that it is probably a compression issue. The images
are probably compressed using a format that didn't exist when LDD3 was
issued.
See if you can take JohnM's (Abyss) advice. If you can open it in Photoshop.
Try saving it under another compression format or as uncompressed. If you
have a lot of them it might be worth the time finding a compression that
works. Uncompressed Tiffs can be HUGE. You'll probably want to say with a
Tiff format so it will still reference the TFW file.
This editor opens it http://www.irfanview.com/
Allen
Message 6 of 8
Looked Ok to me in the 2008 versions. You might want to try going into the
map image options and set the memory used for images up a little bit more
than the default.
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
Message 7 of 8
remmnate
Looks like the irfan conversion to an uncompressed tif is the working the best for now, as far as image quality preservation. Thanks for the help everyone!!
Message 8 of 8
Glad you got something to work!
wrote in message news:5607273@discussion.autodesk.com...
everyone!!
