"Jambruins" wrote in message
news:29774172.1083693388893.JavaMail.jive@jiveforum1.autodesk.com...
> I have a file with 10 different alingments in which each one needs a
plan and profile sheet. Therefore, I have 30 sheets. What is the best way
to reduce the size of my file so it will run faster? If I open my plan and
profile sheets in another drawing and xref the baseplan in I can't update my
frames if they need to be because I can't select a current alignment or
profile? Any advice? Thanks.
Yes you can, you can reference an alignment in any drawing thats in the
same project. When it asks you to select the alignment, just hit enter and
a dialog box will pop up with a list of all defined alignments, just
highlight the one you want and hit ok.
Profiles on the other hand ... you have to be in the drawing where the
profile is.
David
