And you may also wish to look into the options available to you at BudCad:
http://www.budcad.com/AutoGroups.htm
I can recall being able to get the CPOs onto numerous Layers, situated by
their Description, or whatever I decided was best for them.
$100 isn't too high a price to pay for something along those lines I hope.
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
CivilSeries-2K4
Intel Xeon 3.2GHz 2GB RAM
XPPro 32bit SP2
Nvidia Quadro NVS 285 256MB
"The only Constant is Change".
"Allen Jessup" wrote in message
news:5429427@discussion.autodesk.com...
Use QSelsect. Select an Object type of Civil Point Object and an Operator of
Select All. the use the Object selection Icon in the upper right of the
dialog box to do your window selection.
Allen
wrote in message news:5426120@discussion.autodesk.com...
I have a button setup (uses the 'change' command) that turns whatever i
select onto a designated layer.
I would like to be able to window an area (essentially having it select
everything...linework, text, etc.) and have it filter or select just the
civil points in that window. So only the civil points are changed to the
designated layer.
I know i could use the insert point cmd and the window function in there.
But that puts them on the current layer and that is counterproductive, to
the other commands i am using at that time.
