AutoCAD Land Desktop (Read Only)
How to change plot device on multiple layout tabs?
3 REPLIES 3
Ben Brookes
3477 Views, 3 Replies
Hi I'm pretty new to Autocad and was wondering if it is possible to change the plotter on many sheet layouts at the same time.
I have a drawing with 42 layout tabs, and have moved offices and so have a new plotter. I cannot seem to change the plot device on multiple tabs even though my new plotter is the same as the old one only with a different network name. I can go through and change them one at a time but there must be a easier way
Thanks ...BEN...
3 REPLIES 3
in reply to: Ben Brookes
Ben Brookes said the following On 9/29/2006 3:21 AM:
> Thanks ...BEN...
You can do it with a bit of lisp code.
(vlax-for x
(vla-get-Layouts
(vla-get-ActiveDocument
(vlax-get-acad-object)
(vla-put-ConfigName x "Adobe PDF")
Replace "Adobe PDF" with the name of your printer or PC3 file.
R.K. McSwain
http://rkmcswain.blogspot.com
Hi Ben
PUBLISH; will allow you to select overiding pagesetups per layout. So, have
one for each ploter and you in like Flint.
Joe
"R.K. McSwain" wrote in message
news:5345113@discussion.autodesk.com...
> Thanks ...BEN...
(vlax-for x
(vla-get-Layouts
R.K. McSwain
Ben,
I use this little lisp. Somebody (Jason maybe?) posted it on these NGs
a while back, I tried to find the post, but couldn't. So here it is.
Use appload to load it and 'psetup' to run it. It will let you type in
a predefined plot setup and apply to all layouts. It works great.
Shawn
> Thanks ...BEN...
