Ben,
I use this little lisp. Somebody (Jason maybe?) posted it on these NGs
a while back, I tried to find the post, but couldn't. So here it is.
Use appload to load it and 'psetup' to run it. It will let you type in
a predefined plot setup and apply to all layouts. It works great.
Shawn
Ben Brookes wrote:
> Hi I'm pretty new to Autocad and was wondering if it is possible to change the plotter on many sheet layouts at the same time.
> I have a drawing with 42 layout tabs, and have moved offices and so have a new plotter. I cannot seem to change the plot device on multiple tabs even though my new plotter is the same as the old one only with a different network name. I can go through and change them one at a time but there must be a easier way
> Thanks ...BEN...
