AutoCAD Land Desktop (Read Only)
How to Calculate Volume between two surfaces?
6 REPLIES 6
smbutala
3224 Views, 6 Replies
Hallo:
I am trying to calculate volume of a landfill (Airspace). I have contours of bottom plane and top plane. Anybody can please help me how to calculate volumes using Land Desktop?
Thanks in advance
6 REPLIES 6
in reply to: smbutala
Hey smbutala;
To calculate the cubic yards (or meters) produce by this landfill you would
require two Surfaces - Built in Terrain Model Explorer. Usually they are
expressed as Existing Ground (the native terrain prior to construction
activities), and Finish Grade (the user-designed area that produces the
Cut/Fill quantities).
You might spend some time at this site for these regards;
http://tinyurl.com/khqvu
And I would suggest that you access the Land Desktop Help also for your
benefit in handling this (and many more) situation(s) you might find
yourself in.
When you need further answers after your own study, come back and we will
help you figure out alternatives.
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT-2K4
AMD Athlon 64 3200+ 2.2GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce FX 5200 128MB
WD 36GB Raptor
wrote in message news:5141985@discussion.autodesk.com...
Hallo:
Thanks in advance
ddgrips
read the help file about using the "grid" method.
It is easiest and accurate.
smbutala
thanks guys..
IMHO - that would be the least accurate also.
Composite is my "mainstay". Especially since one of it's "benefits" is to
help point out "vertical data" issues.
See the threads regarding them here;
http://tinyurl.com/nvam6
And of course there are differing opinions expressed there.
I've always found that due to the large differences I found by comparing the
three method's numbers against each other in my past, it made far more sense
to use the Composite - as it was usually the most accurate once compared
with the numbers produced by actual Grading operations.
My $1.98 - inflation has an impact everywhere. 🙂
Don Reichle
LDT-2K4
XPPro 32bit SP2
1GB RAM
WD 36GB Raptor
wrote in message
news:5142145@discussion.autodesk.com...
blueyedixie
im assumeing that that is the same thing i need to do to calculate volume of dirt moved from original site to finished site, not to familier with land desktop how would i do this.
Not to start over again Dixie, but you could follow the steps that have been
laid out for you in the other thread - measuring volume.
I'm going to lay on you the same thing I did there;
This is found in Help under the following Title;
Calculating Composite Volumes
Use the Composite method to calculate volumes both for a defined stratum and
parcels within the area of that stratum. For more information about the
Composite method, see Using the Composite Method.
Related topics
Defining a Stratum
Changing the Composite Volume Settings
Calculating Total Site Volumes Using the Composite Method
Calculating Parcel Volumes Using the Composite Method
Look up those four Blue Underlined Titles, and that should get you started
with understanding what you're attempting to handle - all by yourself.
HTH
Don Reichle
LDT/CD-2K4
AMD Athlon 64 X2 Dual 2.01GHz
XPPro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
wrote in message news:5179388@discussion.autodesk.com...
