FWIW, I just tried a small test drawing with Peter's code in LDD3 with the
Land 1.2 reference and it worked just fine.
Jeff
check out www.cadvault.com
"markc01" wrote in message
news:29697948.1109110837126.JavaMail.jive@jiveforum1.autodesk.com...
> OK now we're getting bizarre. I tried it all again, put on some counters
> to count the items, and I'm getting 34 acad points, 0 aeccpoints, and 194
> items examined total. The execution just doesnt see the aeccpoints on
> If TypeOf ent Is AeccPoint Then.....
> For project references, I have Autodesk Land 4.0 type library. I also had
> AEC Base and AEC Objects for a while, but they didn't help.
> Are there any other references, etc I might be missing?
> Is there another machine there you can try it on?
> thanks,
> mark c.
