AutoCAD Land Desktop (Read Only)
Gravel hatch doesn't work in LDD 2006
4 REPLIES 4
798 Views, 4 Replies
I'm having trouble getting the gravel hatch to show up properly in LDD 2006. I've tried the snapbase command but it didn't help. I have also played with the hatch scale and again no success.
Is there a way to fix this.
Maskwa
4 REPLIES 4
Set the "Hatch Origin" in the hatch dialog box. Or type HPORIGIN at the command line.
You could also try moving the UCS temporarily to somewhere close to where you are hatching. (right on the boundary of the hatch works well). It seems that the further away from 0,0,0 the more wrong the hatch is.
AutoCAD incorporates the concept you've described into the 2K6 "package" for
Hatching Finsternis.
My olde use of SNAPBASE became circumvented also. The lower left portion of
the Hatch Dialog Box, has a button for choosing a Base Point nearby to your
Project's area.
The use of NAD27 or NAD84 coordinate systems for Projects, places 0,0,0
pretty far away for Hatching to accommodate!
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT/CD-2K4
AMD Athlon 64 X2 Dual-Core 3800+ 2.01GHz
XP-Pro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
"The only Constant is Change".
wrote in message news:5245954@discussion.autodesk.com...
nodink
In paperspace, I moved all entities closer to 0,0 & re-hatch the area. That should do it.
