This has been bugging me for a long time. Hatching at the drawing origin is not a good solution for me because almost all drawings I use are georeferenced in a coordinate system that places the line work at approximately Northing = 5,950,000 feet and Easting = 2,145,000 feet. So, moving back and forth is very time consuming for every little change!
I'm not sure if this is the same in Land Desktop, but in vanilla AutoCAD and Civil 3D this method works perfectly and is very simple:
https://geauxcad.wordpress.com/2014/05/29/hatching-and-ucs-origin/
In case the above link breaks in the future:
An alternate: upon entering the HATCH command enter the settings dialog by pressing T, then select your origin the same as before.
