As long as you are still able to see a "response" from AutoCAD on the
command line during the MENULOAD, WORKSPACE, SAVEAS, etc. commands then it
sounds like the FILEDIA and CMDDIA settings need refreshing - what John told
you.
Along with John's able advice brannaninc, it's beginning to sound like this
procedure may be in order to get things back to "properly" functioning
order:
http://tinyurl.com/59bc2
That tinyurl will take you to the Technical Support article dealing with
removing all Autodesk products from the registry prior to a re-installation.
HTH
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT/CD-2K4 - SP 2
AMD Athlon 64 X2 Dual-Core 3800+ 2.01GHz
XP-Pro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
"The only Constant is Change".
"John Mayo" wrote in message
news:5319171@discussion.autodesk.com...
It might be that LDT reset one or two system variables and it did not have a
chance to reset because an LDT command was canceled using the ESC key.
Filedia = 1
Cmddia = 1
Using the ESC key to exit a command in AutoCAD is acceptable, this is not so
with LDT. All LDT commands you want to cancel should be run until you are
prompted to cancel/exit or completed.
John
wrote in message news:5319099@discussion.autodesk.com...
We are running LDD 2006. Been working great. Left office on Friday, came
back Tuesday, and now I get no dialog boxes. I can't insert images, i can't
(save as) anything. No one has touched the computer all weekend, yet I
believe settings have changed. Has anyone had this happen, and how do I fix
it? (menuload) doesn't work, neither does (workspace). I've went through
standard repairs and even reinstalled it.
