I would like to know if anyone else has experienced the layout tabs flcikering. This seems to happen when there are to many layout tabs to display along the bottom of the screen, the only way that I have been able to get it to stop is to remove some of the tabs until it stops. Any suggestions on how to correct this?
Sonds to me like a hardware problem. You may be overloading your graphics card. Soo... A little more info, please. What hardware do you have (inc OS), and what version of LDD/LDC are you using.
My guess is that you need either a newer driver for your video card, or more Vram on it.
Reid
I am running on Windows XP and I have this happen in LD3 (2000) and also 2008, that's the highest version I am able to utilize at this point.
Thanks for responding and hopefully someone has the answer.
Dean
Have you tried looking for the newest video drivers for your graphics card?
If you have an IT department, they should be able to help you. If not, go to the manufacturer's web site, locate the card you have & download the drivers. It's not hard to reinstall.
Reid
