AutoCAD Land Desktop (Read Only)
bubbax
244 Views, 3 Replies
faster loads
I recently had problems with AutoCAD not completely loading. It would halt before it finished. The problem turned out to be a service listed under the task manager as "WSCommCtr1.exe". I turned off this service and just to see what would happen, I tried to load AutoCAD. It loaded much faster then ever before and in general the whole process of opening a drawing appeared faster. Anybody have any ideas what this service is and does it really need to be running? So far I haven't noticed any problems when it's off.
3 REPLIES 3
in reply to: bubbax
Here you go. http://cadence.advanstar.com/2003/0603/vpoint0603.html "bubbax" wrote in message news:22454566.1093358310111.JavaMail.jive@jiveforum2.autodesk.com... > I recently had problems with AutoCAD not completely loading. It would halt before it finished. The problem turned out to be a service listed under the task manager as "WSCommCtr1.exe". I turned off this service and just to see what would happen, I tried to load AutoCAD. It loaded much faster then ever before and in general the whole process of opening a drawing appeared faster. Anybody have any ideas what this service is and does it really need to be running? So far I haven't noticed any problems when it's off.
NewtonW
in reply to: bubbax
That is AutoCAD's communication center.
-Newton
NewtonW
in reply to: bubbax
ooops, John is one step ahead of me : )
