1) I am assuming this is a project specific problem - even though you did
say 'any'. Trying opening the landXML export for a very small or sample
project. Does it work? If so, keep reading 2 - 6; if not, you must have
some specific hardware/software conflicts - possible some .dll problems.
Maybe some faulty memeory chips? If it was a corrupt configuration or path,
the Repair should fix it. Make sure you are logged on as an administrator.
Contact your Dealer.
2) If the problem is project specific, I am guessing that you have either a
very large project, or large surface(s) within the project.
3) The Interface LDT LandXML Export routine is not at all user friendly -
the programmers decided to identify all available LDT land data prior, then
letting the user select from the list. The algorithm is very memory and time
intensive.
4) Try reducing the specific project data for the large project. For
example, I have a project called Transfer. If I want to just landXML Export
a particular surface from a given project, I will copy the DTM/Surface
folder to my Transfer project, landXML Export it, then delete the folder,
keeping the Transfer project 'clean.' Same can be done for parcels,
alignments and points.
5) If the problem is a single, large DTM, in a particular project, you may
be out of luck. Remember, if you need to re-import into LDT, the time will
increase geometrically.
6) If you have C3D, you might find better interface times with landXML
operations.
Good luck,
sc
"tsaxy" wrote in message
news:12806836.1101319426991.JavaMail.jive@jiveforum2.autodesk.com...
> Ok my IT man and I have ran the repair, applied SP1 and SP2 and even the
supposed XML fix from acad's support site and this still hasn't fixed the
issue. I've noticed that I get a VBA system error when trying to run the
Export XML feature.
> Please remember, #1 I never make it to the initial dialog box,
> #2 it eats up all 2GB of RAM and the page file, then gives me First a
fatal Error and then secondly in the command line of ACAD a VBA system error
(access violation 0x000005).
> Thanks for all the help everyone. It's still not working though.
> Heidi
