I've already done 5 roads in this project with no problems. I simply modified the profiles and re-ran them after going through all the steps. I have 2 roads that for some reason won't work for me. I keep getting an error saying "error: cannot create cross section topsurface breaklines". Any ideas? I've tried widening/narrowing the sampling swath, I tried re-creating the template. I'm at a loss as to what to do. Thanks.
And just to clarify, I did go back in to the Edit Template and defined the Top Surface, after defining the template. Thanks.
Never figured this one out, but ended up running the surface by points instead of breaklines and that seemed to work.
