AutoCAD Land Desktop (Read Only)
1154 Views, 1 Reply
ECOPY
Has anyone had any experience working with 'ecopy' to create 'pdf' files.
I am having a difficult time, creating an 'ecopy' file from within LDD. I
have successfully created a 'ecopy printer', and where the file should be
dumped into.
I keep getting the following error:
ERROR DISPATCHING TO APPLICATION, DISPATCH ERROR; 2
Zdenko
1 REPLY 1
Don't know about ecopy, but if you are simply looking to export LDD files to
a PDF, I would recommend Acroplot. It works great. I have downloaded the
trial version and it has a gazillion options as it is specificially intended
to be used with AutoCAD. It will export your model space views as well as
all your paper space layouts all at once, or you can select which ones you
want. It even uses your linewidth tables to give the PDF the look of a
plotted drawing.
Now I gotta convince the boss to buy it. It's only $150 for the regular
version. There is a less complex version called Acroplot Jr, that goes for
about $80, last time I checked.
Here is a link...
http://www.cadzation.com
Sorry if that is not what you are looking for.
Haley-Dusa Group
Steve Mann
"Zdenko Novkovic" wrote in message
news:C5A49CEC83FF343992E11AAC40707F09@in.WebX.maYIadrTaRb...
> dumped into.
> Zdenko
