Osnaps? from node to end, mid, near, perp.....
"travanx" wrote in message
news:B22B62EE8CD572FB2089FD1ABB244042@in.WebX.maYIadrTaRb...
> But can you make it so its different each time you label a line and still
> update dynamically? And is there an easier way to do this than going
> through a menu?
> And when moving the point it just asks for the base point and second point
> of displacement. And when I do that the point goes on top of the second
> point of displacement. How do you move it a bearing a distance from
another
> point?
> "Joe bouza" wrote in message
> news:55CDD15D30CA49D214440F980B6CFD01@in.WebX.maYIadrTaRb...
> > Hi,
> > 1. You can set up a line/curve label to just about anything tou want. Go
> to
> > Label/edit label style the dialog box is pretty self explanitory.
> > 2. I always move points by Points/edit points/move. The point setting
> dialog
> > allows you to set thing so acad move will update the point, however, I
> would
> > refrain from using that option.
> > Joe
> > news:18B16D43F69BF5A9192F40AA31C9508C@in.WebX.maYIadrTaRb...
> > > I am trying to figure out if there is a way to use a dynamic label for
a
> > > line and only use either a Bearing or Distance? And if there is an
easy
> > way
> > > to do this?
> > > Also is there a specific wado just about y to move a point to a new
> > location.
