Hi Pat,
Autodesk Survey currently does not support offset observations.
If you wish the Import Field Book command to process the fbk file and ignore
your offset observations, you can edit the file and place an exclamation
mark at the beginning of the line of data that contains the offset coding..
Henry
Henry Sanders
Autodesk ISD Civil Test Development
"Pat Bjork"
wrote in message
news:419221b2$1_3@newsprd01...
> We are fairly new to Land Desktop / Civil / Survey. I am trying to figure
> out the procedure for downloading our topographic surveys into Survey
2005.
> We use Leica total station with produces a gsi file format. This is what I
> am doing so far. I convert the Leica raw data file to a field book using
> Carlson Connect. Carlson Connect > Leica > Point/Raw Data Transfer. I then
> edit the newly created field book file to add the coordinates for the
> starting point and backsite. Then I try to import the feildbook file. It
> starts the process then comes to the first error. Line 28: Error: Figure
> 'RIGHT' not found. Error occured. Stop Import Process? Line 48 in the
field
> book reads "OFFSET RIGHT 2.00". When the surveyor shot this point in the
> field he put in an observation shift to the right 2'. I would like to know
> how this line should read in the fieldbook file so that LDD understands
the
> shift. Any and all help is greatly appriciated.
> Thanks,
> Pat
