AutoCAD Land Desktop (Read Only)
Disappearing lines & contours when editing from negative elevations
2 REPLIES 2
annw2
1064 Views, 2 Replies
We get files from other firms that have property lines with a vertex at big negative numbers. Modify the negative number to 0 & the line disappears.
The same thing happens with edit contour elevation from big negative to correct elevation. Contour poly line vanishes.
Anyone have any ideas?
Ann Wingert, P.E.
2 REPLIES 2
in reply to: annw2
If the lines have a linetype other than continuous. Set them to continuous
before changing the elevation. They may have played with the linetype so it
LOOKED right at the 3D slope.
Allen
wrote in message news:5104746@discussion.autodesk.com...
in reply to: annw2
Are these "other firms" using Survcad by any chance?
I often have this problem with Survcad files. Running Flatten first seems
to help. Of course you have to re-elevate the contours then. Overall a
real PITA.
Doug K
LDT 2005, XP Pro 2002 sp2, P4 2.40GHz, 1 GB RAM, Dual 19" Dell LCD, NVIDIA
GeForce FX 5700LE, Left Handed Kensington Trackball, Happily Married
w/Children
