Could it be in your point settings > desc key tab you don't have the
option "match on description parameters" selected
From help file:
Under Matching Options, select or clear the Match on Description
Parameters ($1, $2, etc.) check box:
Select the Match on Description Parameters ($1, $2, etc.) check box to
use description parameters in the description format, and for scaling
and rotating the description key symbols.
Clear the Match on Description Parameters ($1, $2, etc.) check box if
you do not want to use description parameters in the description format
and for scaling and rotating the description key symbols.
jon_fergus wrote:
> Actually, correct that last reply. The Desc Format $0 does not work at all as far as I can see.
> I have a single point with the raw desc "252" and when I set the Description Format to "$0-CB" the full description reads "$0-CB" and NOT "252-CB" as desired. Is there another setting somewhere I am not aware of, or is this just some kind of error?
