Did you try searching the Knowledgebase and this NG on the Web side? I think
I recall seeing this discussed quite some time ago. A few years ago maybe.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2007, LDT 2007, Raster Design 2007
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5424982@discussion.autodesk.com...
Hi Don,
LDT is set to FL83-NF, and the horizontal location of the incoming contours
is fine - LDT is handling the transformation of Meters is the DEM file to
Feet in the drawing properly. unfortunately, it's applying the same
transformation to the elevation data, which is in the DEM file in feet.
Somehow, I need to either get LDT to ignore the conversion on the Z data, or
somehow convert the DEM to use consistent units for both horizontal and
vertical control.
LDT 2006, SP1
