AutoCAD Land Desktop (Read Only)
Defining North...other than up
6 REPLIES 6
692 Views, 6 Replies
In DCA, you could tell the program that a certain line was to be a certain
bearing, i.e. you could tell it that a line going from SW to NE was to be
due North.
Is there anyway to do that in LDD?
Steve (C3D 2009 LDC)
6 REPLIES 6
Ddunits > Direction and try other. I really don't mess with this, I use Dview twist if I need to have north in another direction besides straight up.
Projects menu, Drawing Setup, Orientation tab. You can set the Base Point
and North Rotation there.
"Steve Adams" wrote in message
news:6397380@discussion.autodesk.com...
> due North.
> Thanks,
Thanks Jeff!
>> due North.
>> Thanks,
Since LDD is a dead program, my advice is not change the North Rotation.
Civil 3D does not use it. It is too easy to rotate plan objects in a
viewport.
Bill
The biggest problem, though, is LDT labels do not rotate to display
correctly and you cannot use UCS's to work around that problem.....which, I
think, was the driving force behind the BP/NR idea.
Steve, Bill's comment does warrant me to advise you to make absolutely sure
you have a North arrow and a known coordinate point labeled. This is so the
drawing can be correctly inserted and rotated to a drawing which doesn't
use, or know about, north rotation.
Jeff
"wfb" wrote in message
news:6399262@discussion.autodesk.com...
> viewport.
> Bill
Thanks Bill and Jeff.
I'll probably stay away from LDD alternate north rotation, and just use lisp
to custom label my lines, leaving the acad coords unchanged.
But this a common problem with survey plats: the field work is often based
on SPC, but you need to use a deed bearing system
for purpose of comparison to the local deeds.
"Jeff Mishler" wrote in message
news:6399404@discussion.autodesk.com...
Jeff
> viewport.
> Bill
