Thanks Bill and Jeff.
I'll probably stay away from LDD alternate north rotation, and just use lisp
to custom label my lines, leaving the acad coords unchanged.
But this a common problem with survey plats: the field work is often based
on SPC, but you need to use a deed bearing system
for purpose of comparison to the local deeds.
"Jeff Mishler" wrote in message
news:6399404@discussion.autodesk.com...
The biggest problem, though, is LDT labels do not rotate to display
correctly and you cannot use UCS's to work around that problem.....which, I
think, was the driving force behind the BP/NR idea.
Steve, Bill's comment does warrant me to advise you to make absolutely sure
you have a North arrow and a known coordinate point labeled. This is so the
drawing can be correctly inserted and rotated to a drawing which doesn't
use, or know about, north rotation.
Jeff
"wfb" wrote in message
news:6399262@discussion.autodesk.com...
> Since LDD is a dead program, my advice is not change the North Rotation.
> Civil 3D does not use it. It is too easy to rotate plan objects in a
> viewport.
> Bill
