AutoCAD Land Desktop (Read Only)
Cut Fill calculations in meters?
2 REPLIES 2
hayleyannp
1441 Views, 2 Replies
LD 2006, performing volume calculations. I read on a separate post that calculations are given in "cubic yards" - does the program run a calculation assuming the contours are in feet?
The units in our drawing are set to decimal. The volumes seem low - I was wondering if we were to backtrack and cube the "cubic yard" calculation if that would really be the cubic meter calculation? It would make sense if the program is running an automatic "feet to yards" calculation.....
2 REPLIES 2
K_Woodruff
in reply to: hayleyannp
What is your drawing setup for? If you go to the Project menu and select 'Drawing Setup' then select the tab 'Units' is it set for feet or meters?
pirai
in reply to: K_Woodruff
the autodesk 2014 populate not working in meters so i want some ideas to work for populate with mesurements of meters.
can anybody help me?
