AutoCAD Land Desktop (Read Only)
Cut and Fill Factors - Stratums
4 REPLIES 4
marathon
20435 Views, 4 Replies
While using the Grid Volume Method for producing Cut and Fills we wanted to include the volume correction factor of 0.85 for fill (fill will campact to only 85% of what is used). When caluclating the cut and fill with the factor it seems to work incorrectly. The fill is reduced by 15%. If I am thinking of this correctly it should increase by 15%. Meaning we would need more fill to make up for the compaction.
The Help says "Type a Cut factor and a Fill factor for the Grid Volumes Corrections values. These values compensate for expansion and compaction of the surface material, and help to determine the actual volume of material that needs to be removed (the cut factor) or added (the fill factor) to the site.
n Cut factor: Compensates for the expansion factor of the material left after the cut.
n Fill factor: Compensates for the compaction factor of the fill material.
For example, for a material that expands 15 percent, type the value 1.15. However, for a material that compacts to 93 percent of its original value, type 0.93. A factor of 1.00 does not adjust the volumes"
Am I doing this wrong?
Maria
4 REPLIES 4
in reply to: marathon
We usually use 1.18 for fill.
There was a lengthy and informative discussion in
the old land-desktop3 group last year, I think.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
While
after the cut.
fill material.
Maria
It's easy to get confused and if we throw
things like moisture/density ratios and modified proctor densities into the
mix it quickly gets worse. Basically, we
calculate post-
excavation volume
and pre-compaction volume. I like to think of it in terms of, "How
much dirt is in the truck?" If I dig 100 cubic yards and it expands to 115 cubic
yards in the truck my expansion factor is 115%. (Think of the original
dirt, in the hole, as being compacted at 100% proctor density.) Now,
we need to fill that same hole but our design requires the soil to be
compacted to only 95% proctor density. How much dirt on my truck would
fill that 100 cubic yard hole if I compressed it 95%? The most common
answer would be 105 cubic yards but the true volume would be slightly higher.
Does that answer your question?
While
after the cut.
fill material.
Maria
The volume correction factors simply multiply the
unadjusted Cut volume and the unadjusted Fill volume by the factors you
supply. Nothing more....Deep breath
Now that you know that (and you've proven it
yourself) you can apply them as you wish.
For guidance purposes:  we typically use Cut =
1.0 and Fill = 1.15 to 1.22.
We use the Cut = 1.0 because my clients and
contractors basically want to know how much they're cutting into the
ground on a 1:1 basis.
We use the Fill factors as stated, because 1)
usually the Fill is compacted to a higher density than the in-situ
(unless rock), 2) losses in transport, wind , erosion,  and 3) factor
of safety, don't want to be short because it is usually less expensive to spill
dirt on the site than have to import.
So taking into account all that,
all we're basically saying is it takes 15%-22% extra volume to fill that
unadjusted Fill volume. I don't see any reason to move the Cut factor from 1.0,
 unless the Cut fluffs up and your concerned about how many truckloads
maybe. But then you have to realize your using a fluffed Cut number to
balance your Fill. It also helps for some reason to look at just the Cut
and Fill numbers themselves,  not the Net, and think about what you've
got due to the factors you've  supplied.
That's my experience, but since you've proven to
yourself what the factors do,  use them as you wish. Kind of anti-climatic,
I know.
Oh yeah, don't forget to strip your site of topsoil
first:)
Fred
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">While
after the cut.
fill material.
Maria
marathon
Thanks for the help!!!!!
