becca12306 wrote:
> In the workspaces toolbar you where you can switch between Land desktop and civil design I'm experiencing a problem. Forgive me if I don't know the terminology, I'm not real savvy when it comes to the software stuff. The issue is I seem to not have any "cui" files. No matter what I set the workspace on it stays the same. I type "menu" and select civil and i loose half of cad!
> It's probably something simple but without an on site tech person I'm afraid I'll make it worse if I mess with it.
The main menu should be LAND.CUI, not CIVILDESIGN.CUI.
Allen's advise it right on. If CIVILDESIGN.CUI is corrupted
(happened a lot in 2006) - then you need to replace it.
R.K. McSwain
http://rkmcswain.blogspot.com
