Nancy it might be beneficial if you could share some more of the parameters
of this situation?
If you have no Templates, then I have to assume that you have no Final
Design at this point?
snip>I have an alignment and cross sections of existing ground every 50'
along alignment. I need a file listing the offsets and elevations of my
cross sections.
It would seem to me from that portion of your post, that someone needs to be
able to see where the Alignment's location will roughly be situated out in
the field.
And since you've stated that you already have the cross sections, then a
competent surveyor should be able to use that data to place the viewing
lath?
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
C3D/LDT/CD-2K7 SP2A
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
"John Mayo" wrote in message
news:5517017@discussion.autodesk.com...
I don't believe LDT will do this automatically. You could manually set
points on the surface in plan & create a point table.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2007, LDT 2007, Raster Design 2007
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5517025@discussion.autodesk.com...
I am using LDD 2006. I have an alignment and cross sections of existing
ground every 50' along alignment. I need a file listing the offsets and
elevations of my cross sections. I have searched the previous postings,
tried help menu, took out the books, etc, but can't find out how to do this.
I have no templates, just existing ground. Any help would be appreciated.
Thanks.
