Match figure name with point description: Connects figure line work to
points that have the same descriptor as the current figure name. When this
box is cleared, the figure is drawn sequentially from point to point
regardless of point descriptor.
It might also depend on the conversions you use.
Bud Miller
www.BudCAD.com
Legal descriptions and more in LDT
"Dennis Hyman" wrote in message
news:421a2d16$1_2@newsprd01...
>I couldn't really tell you.....I'm not the manager of the crews, I'm a
>draftsman in the survey department, with additional IT duties, such as
>solving ACAD problems, printer issues, etc. I even run the backups and
>restores for the server, at times. It's amazing I get anything done, with
>all things considered. What kind of setting should I be looking for that
>would allow the elimination of the "end" command?
> "Bud" wrote in message news:421a1b96_1@newsprd01...
>> Hi Dennis,
>> Are your collector settings correct? I've never entered an END code and
>> none of the crews I work with do either (SDR33's and Nikon DTM's). We
>> only ever use B, C3 and R. The conversion takes care of the ENDs (not
>> sure about Trimble) as long as the collector settings in LDT are correct
>> (match figure name to desc.).
>> Bud Miller
>> www.BudCAD.com
>> news:4219fd4c$1_1@newsprd01...
>>> Every time an instrument man here misses an END code, you can tell. All
>>> points up to the next begin are connected. And God forbid that they
>>> missed an END code right before doing ground topo for a 30 acre sight!!!
>>> We use SDR-33's and Trimble collectors, dumping into LDD2004.
>>> "Bud Miller" wrote in message
>>> news:4216c1cd_2@newsprd01...
>>>> There's no realy need to collect sequentially and manually entering END
>>>> codes is not necessary. The conversion process inserts the END commands
>>>> automatically when another code is encountered.
>>>> A dilligent crew is essential but once they get the process down (which
>>>> really doesn't take long) it's the fastest way to work.
>>>> Bud Miller
>>>> www.BudCAD.com
>>>> Legal descriptions and more in LDT.
>>>> "Sbaumer" wrote in message
>>>> news:4216ab2a_3@newsprd01...
>>>>> You need a party chief that can handle it first. We use BOC1 for Back
>>>>> of
>>>>> Curb or TB1 for Top Bank 1. If crew collects data and enters BEG(TDS
>>>>> Program) then shoots first back of curb point and describes it as
>>>>> BOC1, then
>>>>> the simplest way is to go to next back of curb shot and use BOC1
>>>>> again,
>>>>> repeat till the end of curb shots and put an END statement. Convert
>>>>> your raw
>>>>> data to a fieldbook file and import flb file and it should draw line.
>>>>> You
>>>>> will have to experiment with figures program to put on layers and
>>>>> linetype
>>>>> you need.This is a VERY simple example we use successfully. Then
>>>>> again, we
>>>>> have strayed from this, because our draftsmen can usually draw a days
>>>>> worth
>>>>> of line work from node to node or by point number range in 10-15
>>>>> minutes
>>>>> without any blown code entries from field (inexperienced Party
>>>>> Chiefs)that
>>>>> leads to a spider web on the screen.
>>>>> Sbaumer
>>>>> "John Michalik" wrote in message
>>>>> news:4215f1f2$1_3@newsprd01...
>>>>>> You're welcome. Good luck.
>>>>>> John Michalik
>>>>>> Drafting and Design
>>>>>> LDD/CAD Development & Standards
>>>>>> johnm@weissereng.com
>>>>>> "tjboyer" wrote in message
>>>>>> news:1880077.1108669410277.JavaMail.jive@jiveforum2.autodesk.com...
>>>>>> > Thanks Bud and John!
