AutoCAD Land Desktop (Read Only)
Convert Radians to Bearing?
13 REPLIES 13
Message 1 of 14
3233 Views, 13 Replies
Using VBA in LDT3, what is the best way to convert the angle of a line from
Radians to either an Azimuth or Bearing?
TIA, Gene
13 REPLIES 13
Message 2 of 14
Off the top of my head you multiply by 180/pi to get the azimuth from
radians.
Depending on what format you want the output to be in you may need to use:
angletoreal and angletostring for conversion.
If you let me know the desired output I'll send you better instructions.
Bud Miller
www.BudCAD.com
Legal Descriptions. Parcel Reports.
Point Group Automation. Layer Reports.
"Gene Redmon" wrote in message
news:F087EEE7445DE8F25ACFB6497919BC43@in.WebX.maYIadrTaRb...
from
> TIA, Gene
Message 3 of 14
Thanks for the assistance Bud. I'm trying to format the angle in:
DegreesMinutesSeconds for the Azimuth and Bearings both. If I'm not
mistaking
your suggestion will give me the Azimuth in decimal degrees and I'll need to
convert
that to DDMMSS?
Gene
"Bud Miller" wrote in message
news:3124F28BC0D2BFBAA6B97BD62DFCB768@in.WebX.maYIadrTaRb...
> radians.
> Bud Miller
> www.BudCAD.com
> from
> > TIA, Gene
Message 4 of 14
I just stumbled on an almost undocumented "AngleToString" method. I don't know VBA but it's used on the Aecc.Application.ActiveDocument.Utility object...
Sub Example_Utility()
' This example returns the AngleToString value for 0.785398 radians using
' the active document.
Dim doc As AeccDocumen
tSet doc = AeccApplication.ActiveDocument
MsgBox "The setting for AngleToString is " & doc.Utility.AngleToString(0.785398, acDegrees, 4) _
, vbInformation, "Utility Example"
End Sub
Using Visual Lisp, you can see that the acDegree parameter is actual a format designation, and the last paramter is precision....
Command: (setq |aeccapp (vl-catch-all-apply 'vla-getinterfaceobject (list
*acad* "aecc.application")))
Command: (setq |aeccdoc (vlax-get |aeccapp "ActiveDocument"))
Command: (setq |aeccutil (vlax-get |aeccdoc "Utility"))
Command: (vla-angletostring |aeccutil 0.5 0 2)
"28.65"
Command: (vla-angletostring |aeccutil 0.5 0 4)
"28.6479"
Command: (vla-angletostring |aeccutil 0.5 1 4)
"28d38'52\""
Command: (vla-angletostring |aeccutil 0.5 2 4)
"31.8310g"
Command: (vla-angletostring |aeccutil 0.5 3 4)
"0.5000r"
Command: (vla-angletostring |aeccutil 0.5 4 4)
"N 61d21'8\" E"
John Uhden, Cadlantic/formerly CADvantage
[ mailto:juhden@cadlantic.com ]
[ http://www.cadlantic.com ]
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"Gene Redmon" wrote in message news:F087EEE7445DE8F25ACFB6497919BC43@in.WebX.maYIadrTaRb...
> TIA, Gene
Message 5 of 14
It's also fairly straight forward if you want to calc it yourself if you
need more control over the string formating. Once you get the decimal degree
value, to get the degree portion of the DMS value you convert the direction
to an integer. This will truncate the numbers to the right of the decimal
point. You then subtract the Deg value from the decimal degree value then
multiple by 60 you get the decimal minutes. then repeat the procedure for
the seconds.
In this example, the original decDeg is a double, the Deg and Min variables
are integers and the Sec variable is a double to carry the seconds
precision.
deg = Int(decDeg)
decDeg= (decDeg- Int(decDeg)) * 60
min = Int(decDeg)
sec = RoundVal(decDeg, 0))
' check for values rounded to 60
If sec >= 60 Then
sec = sec - 60
min = min + 1
If min >= 60 Then
min = min - 60
deg = deg + 1
' format the strings
sDeg = CStr(deg)
If sDeg = "0" Then sDeg = "00" & sDeg
sMin = CStr(min)
If Len(sMin) = 1 Then sMin = "0" & sMin
sSec = CStr(sec)
If Len(sSec) = 1 Then sSec = "0" & sSec
sDMS= sDeg & "-" & sMin & "-" & sSec
This gives the azimuth. If you want bearings you first need to get the
correct quadrant and angle.
Glen
"John Uhden" wrote in message
news:6CCA4AD1BA04E7219FC98360C26B9C2B@in.WebX.maYIadrTaRb...
object...
Message 6 of 14
Thanks, Glen. We probably all knew that, but my concern was that his interpretation of the angle was w/r/t the drawing's North rotation. I beleive the AngleToString method incorporates that.
So when is Pipeworks going to let me enter inverts in the tabular editor without recalculating the whole d____d run? Did you realize that this June we're coming up on the 10th anniversary of its failure to work correctly?
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"Glen Albert" wrote in message news:679F3F890E14A4020B7D36618D84409E@in.WebX.maYIadrTaRb...
> the seconds.
> precision.
> deg = Int(decDeg)
> min = Int(decDeg)
> If sec >= 60 Then
> sec = sec - 60
> min = min + 1
> End If
> If min >= 60 Then
> min = min - 60
> deg = deg + 1
> End If
> sDeg = CStr(deg)
> sMin = CStr(min)
> sSec = CStr(sec)
> Glen
> object...
Message 7 of 14
This will work with a north rotation of 0 (north straight up).
To use it with NR you'll need to get the angle by converting the XY of the
start and end points to North/East.
unit = acDegreeMinuteSeconds
bearinquest = ent.Angle * (180 / pi)
select case bearinquest
case < 90
bearinquest = Abs(90 - bearinquest)
'similar statements to correct the angle for each quadrant
end select
bearinquest = ActiveDocument.Utility.AngleToReal(bearinquest, acDegrees)
converted = ActiveDocument.Utility.AngleToString(bearinquest, unit, 4)
'convert to min etc
Bud Miller
www.BudCAD.com
Try the only Legal Writer that reads parcels directly!
news:810419FD7A252ED6108C2D18CFF0EFA6@in.WebX.maYIadrTaRb...
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
degree
direction
decimal
then
for
> > the seconds.
variables
> > precision.
> > deg = Int(decDeg)
> > min = Int(decDeg)
> > If sec >= 60 Then
> > sec = sec - 60
> > min = min + 1
> > End If
> > If min >= 60 Then
> > min = min - 60
> > deg = deg + 1
> > End If
> > sDeg = CStr(deg)
> > sMin = CStr(min)
> > sSec = CStr(sec)
> > Glen
don't
> > object...
Message 8 of 14
Well, whadoyaknow. Seems like a pretty useless function relative to the Utility object. Thanks for the info, Bud.
BTW, do you have any documentation on the dxf values in the "AEC_VARS_DWG_SETUP" dictionary?
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"Bud" wrote in message news:CCFAF8FF20879105FFED13D7A4864586@in.WebX.maYIadrTaRb...
> case < 90
> end select
> 'convert to min etc
> Bud Miller
> www.BudCAD.com
> > 2 Village Road
> > Sea Girt, NJ 08750
> > Tel. 732-974-1711
> degree
> direction
> decimal
> then
> for
> > > the seconds.
> variables
> > > precision.
> > > deg = Int(decDeg)
> > > min = Int(decDeg)
> > > If sec >= 60 Then
> > > sec = sec - 60
> > > min = min + 1
> > > End If
> > > If min >= 60 Then
> > > min = min - 60
> > > deg = deg + 1
> > > End If
> > > sDeg = CStr(deg)
> > > sMin = CStr(min)
> > > sSec = CStr(sec)
> > > Glen
> don't
> > > object...
Message 9 of 14
This will get you the bearing (without a direction) from a selected line
when the drawing is north rotated:
(To get the direction you'd need to add a case statement that checks the N/E
of the start and endpoints relative to each other.)
Dim util As AeccUtility
Set util = AeccApplication.ActiveDocument.Utility
Dim var1 As Variant
Dim var2 As Variant
ptXY = ent.StartPoint
ptXY2 = ent.EndPoint
' Convert point to Easting, Northing
var1 = util.XyToEastNorth(ptXY)
var2 = util.XyToEastNorth(ptXY2)
opp = Abs(var1(0) - var2(0))
adj = Abs(var1(1) - var2(1))
dratio = opp / adj
newbearing = Atn(dratio) 'inverse tangent
Bud Miller
www.BudCAD.com
> case < 90
> end select
> 'convert to min etc
> Bud Miller
> www.BudCAD.com
June
> > 2 Village Road
> > Sea Girt, NJ 08750
> > Tel. 732-974-1711
you
> degree
> direction
> decimal
> then
> for
> > > the seconds.
> variables
> > > precision.
> > > deg = Int(decDeg)
> > > min = Int(decDeg)
> > > If sec >= 60 Then
> > > sec = sec - 60
> > > min = min + 1
> > > End If
> > > If min >= 60 Then
> > > min = min - 60
> > > deg = deg + 1
> > > End If
> > > sDeg = CStr(deg)
> > > sMin = CStr(min)
> > > sSec = CStr(sec)
> > > Glen
> don't
> > > object...
Message 10 of 14
Thanks to everyone that responded. You all provided many solutions that
product
great results.
One other thing I'm stuggling with is, once I get these string values I'm
writing them to a text file.
Of course, since they are Strings they are entered into the text file with
quotes around them. "String"
Is there anyway to prevent the quotes from being placed in the text file?
Gene
news:2EC6ED4834D30BBB422B56C4EFE37668@in.WebX.maYIadrTaRb...
N/E
> Dim var1 As Variant
> Dim var2 As Variant
> dratio = opp / adj
> Bud Miller
> www.BudCAD.com
the
> > case < 90
> > end select
> > 'convert to min etc
> > Bud Miller
> > www.BudCAD.com
editor
> June
correctly?
> > > 2 Village Road
> > > Sea Girt, NJ 08750
> > > Tel. 732-974-1711
> you
decimal
> > degree
> > direction
> > decimal
> > then
procedure
> > for
> > > > the seconds.
> > variables
> > > > precision.
> > > > deg = Int(decDeg)
> > > > min = Int(decDeg)
> > > > If sec >= 60 Then
> > > > sec = sec - 60
> > > > min = min + 1
> > > > End If
> > > > If min >= 60 Then
> > > > min = min - 60
> > > > deg = deg + 1
> > > > End If
> > > > sDeg = CStr(deg)
> > > > sMin = CStr(min)
> > > > sSec = CStr(sec)
the
> > > > Glen
I
> > don't
> > > > object...
Message 11 of 14
Hi John,
Sorry I'm not familiar with those.
Bud Miller
www.BudCAD.com
news:855B59143D3E5B450BBBA056414E8A3E@in.WebX.maYIadrTaRb...
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
the
> > case < 90
> > end select
> > 'convert to min etc
> > Bud Miller
> > www.BudCAD.com
editor
June
correctly?
> > > 2 Village Road
> > > Sea Girt, NJ 08750
> > > Tel. 732-974-1711
you
decimal
> > degree
> > direction
> > decimal
> > then
procedure
> > for
> > > > the seconds.
> > variables
> > > > precision.
> > > > deg = Int(decDeg)
> > > > min = Int(decDeg)
> > > > If sec >= 60 Then
> > > > sec = sec - 60
> > > > min = min + 1
> > > > End If
> > > > If min >= 60 Then
> > > > min = min - 60
> > > > deg = deg + 1
> > > > End If
> > > > sDeg = CStr(deg)
> > > > sMin = CStr(min)
> > > > sSec = CStr(sec)
the
> > > > Glen
I
> > don't
> > > > object...
Message 12 of 14
Hmmm ... if you want additional control over the string you may need to do
what Glen had in his first response. His idea would add leading zeros and
you can leave out the quotes. I don't like the fact that
Utility.AngleToString sub does not leave leading zeros ... don't ask me why.
Andy
Message 13 of 14
If I've got dwg x,y coords, I first convert to n/e before calc'ing the
direction to account for the north rotation. I'm not involved with pipeworks
so I can't help you there.
Glen
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
degree
direction
decimal
then
for
> > the seconds.
variables
> > precision.
> > deg = Int(decDeg)
> > min = Int(decDeg)
> > If sec >= 60 Then
> > sec = sec - 60
> > min = min + 1
> > End If
> > If min >= 60 Then
> > min = min - 60
> > deg = deg + 1
> > End If
> > sDeg = CStr(deg)
> > sMin = CStr(min)
> > sSec = CStr(sec)
> > Glen
don't
> > object...
Message 14 of 14
Hi Gene,
If you "Print" to a file the quote marks are left off.
If you "Write" to a file the quote marks are left in.
Laurie Comerford
CADApps
www.cadapps.com.au
news:507EC0890283C4BF52B9463FF036626E@in.WebX.maYIadrTaRb...
> product
> great results.
> Gene
> N/E
> > Dim var1 As Variant
> > Dim var2 As Variant
> > dratio = opp / adj
> > Bud Miller
> > www.BudCAD.com
> the
> > > case < 90
> > > end select
acDegrees)
> > > 'convert to min etc
> > > Bud Miller
> > > www.BudCAD.com
his
> editor
> > June
> correctly?
> > > > 2 Village Road
> > > > Sea Girt, NJ 08750
> > > > Tel. 732-974-1711
if
> > you
> decimal
> > > degree
> > > direction
> > > decimal
value
> > > then
> procedure
> > > for
> > > > > the seconds.
> > > variables
> > > > > precision.
> > > > > deg = Int(decDeg)
> > > > > min = Int(decDeg)
> > > > > If sec >= 60 Then
> > > > > sec = sec - 60
> > > > > min = min + 1
> > > > > End If
> > > > > If min >= 60 Then
> > > > > min = min - 60
> > > > > deg = deg + 1
> > > > > End If
> > > > > sDeg = CStr(deg)
> > > > > sMin = CStr(min)
> > > > > sSec = CStr(sec)
> the
> > > > > Glen
method.
> I
> > > don't
> > > > > object...
