No...we are still having to address the multiple view/scale issue using
multiple contours on different layers. Once the contours are created and
labeled, you simply run a layer copy to a scaled layer...say C20-Cont-Minr &
C20-Cont-Majr. Then we have pre-defined contour styles based on scale using
a label text style set to 0 height...let the contour style define the text
style for that scale. Example 20-Contour sets text height to 2. Reset the
copied contours to that style for use in a 20-scale viewport. So we still
deal with multiple contours on top of each other isolated by layer. With
the smart objects in AutoCAD now, I do not know why AutoDesk cannot have
text labels automatically display based on viewport scale just like
linetypes do....but if I knew how to do this...I wouldn't be asking so many
questions (grin). If there is a better work-around to this...please post!!
Don
"Matt Crandall" wrote in message
news:C7585F8B24E0C4FA506D3766AB76272B@in.WebX.maYIadrTaRb...
> Don,
> I would be very interested in how you solved that particular issue. I am
> facing the very same thing.
> I have developed a script that, with a single click, plots all layouts to
> DWF Eplots. It creates a doument library that anyone in the office can
view
> and plot plans from. The only issue I am running into are layouts in the
> same drawing that must plot at different scales.... and the only roadblock
> there is those dang labels on the contours.
> So, you are saying that you have the same contours on seperate layers?
> Any help would be greatly appreciated!
> Matt
> "Don Bruce" wrote in message
> news:91E4E53BFD65574BFD715773E14E4F18@in.WebX.maYIadrTaRb...
> > We have different styles of contours depending on how they are used,
> > Existing/Proposed/Background. Each placed on their own layer. Also
> contour
> > styles are set to a specific scaled name in order for text labels to
> appear
> > properly. Wanted a routine that would change styles and layer all in
one
> > shot with a simple macro.
> > Thanks
> > "Glen Albert" wrote in message
> > news:DA918AC827ACFAF8BACF005962CF291D@in.WebX.maYIadrTaRb...
> > > Don
> > > If you are looking for a command line method, I don't believe it
exists.
> > > With VBA you can create a different method of changing the, then look
at
> > the
> > > ContourStyle property on the AeccContour object in the Land ActiveX
and
> > VBA
> > > Reference help file. How do you want to change the style?
> > > Glen
