"dd" is now a hardcoded command in LDT. You cannot change it unless you
first undefine it. That would be like creating an alias of "circle" to copy
a line, it just won't let you do it. I ended up changing my "dd" alias to
"ddd".
Hey programmer dudes! Don't use such short names for commands! We want to
be able to change them to something else!
Brian
"David Prontnicki" wrote in message
news:41485317_3@newsprd01...
> I have changed the pgp file as well as using the command alias editor
> under express tools, they both have my command alias but when I go to
> use it I get a different command. Anybody know what's up.
> I changed DDEDIT from ED to DD, but when I type DD within AutoCad it
> executes another command. I would love to tell you what command it is,
> but it does not list it. What is does say is "Command: DD
> Select line or [Points]:".
> I have looked through both the .pgp file and the command alias editor
> and there is no other command that uses the alias DD. Is there another
> set of commands that I am not aware of?
