Hi Tim,
If you are on the same machine with LDD R2, simply start the AEC Enabled
AutoCAD from the Start menu.
If you are on another machine install the Object Enabler.
You can download it and all needed documentation.
Regards
Laurie
L E Comerford BE(Civ); Dip T&RP; Dip Project Management; CE; MIE(Aust);
CPEng.
AutoCAD Land Development Desktop Application Engineer
CADApps Australia
Suite 102, 3 Chester Street,
Oakleigh 3166
Australia
ph: 03 9568 0077 ext 205
mob: 0418 532 684
fax: 03 9568 0044
email: laurie@cadapps.com.au
web: www.cadapps.com.au
Tim Nary wrote in message
news:ef28e5c.-1@WebX.SaUCah8kaAW...
Is it possible to use VBA in Autocad2000 to edit the display properties of
an AECC_POINT object? We have users that spend the majority of their time in
plain ACAD2000 and wish to do simple things like turn off the point number
or description, rotate, or resize the points, etc.... It becomes a pain for
them to have to quit out of Autocad, Load LDD2, and create a project that
they may or may not need just to affect the display properties of an Autocad
entity. IF we are unable to control the looks of these points from Autocad
somehow, I guess we will end up using the softdesk point block as a label, I
just HATE the idea of duplicate entities. I know that they are not exactly
duplicate, one is the point, and one is the label but still......
