I'm doing a subdivision of an iregular shaped lot. I have a point on the back line that I know will be the start of the dividing line. Is there a way to draw a line from this point to hit the front property line by inputting an exact area that I need the newly created lot to be? I.E. I need the Lot to be 125,000 SF, can I draw a line from the back to a point on line in the front that will give the divided lot an area of exactly 125,000 S.F.?
Use the Swing on Line command to size a parcel by swinging a bearing line from a known point along a line. Original parcel lines must be present in the drawing in order to use this command. For more information, see Drawing Parcels.
Have you done the parcls tutorial yet? It'll help.
Reid
