AutoCAD Land Desktop
Active Member
hawkeng
Message 1 of 2 (200 Views)
Clipboard from 2010 to 2009
200 Views, 1 Replies
03-23-2010 07:03 AM
We installed AutoCAD 2010 & Carlson 2010 on most of our systems. My system is still running LDD2009 with Carlson 2010. We have all drawings set to save back to 2007 verison. Now when I open any drawings saved with the AutoCAD 2010 using LDD2009 the clipboard will not work. It says 'invalid' when I try to paste/paste to orig. It doesn't matter if it I try to copy/paste from the current drawing or from another one in. I can have a second drawing window open with a new or old cad file and the clipboard will work in it. If I open a Microsoft Word document and copy clipboard from there it will paste into the saved AutoCAD 2010 drawing. Any ideas? Edited by: hawkeng on Mar 23, 2010 11:31 AM
Distinguished Contributor
omc-usnr
Message 2 of 2 (200 Views)
Re: Clipboard from 2010 to 2009
03-27-2010 08:38 AM in reply to: hawkeng
Autocad 2010 files are not backward compatible with 09-. What you would have to do is to wblock out, save the block to 2007 then import that. You can't use the clipboard to back down. Takes more steps, but it's doable.
Also, if you go to C3d, the civil objects won't transfer. You'll have to xml them out and import them into LDC w/ xml.
Reid
