Yes, the connect points do show in the template, and yes I did mean Civil
Design 3, not Civil 3D. The help article that you pasted does not apply
since I am not receiving any error messages.The road output problem seems
related to the point code table though since it will work if I assign a user
defined code to the template.
Thank you for replying.
"Don Reichle" wrote in message
news:42168404_1@newsprd01...
> Hey Neil;
> Do the Connection Points display properly in your View/Edit Sections?
> While there is no Knowledge Base match for your exact problem, there is
> one
> that is reminiscent of the problem you're expressing:
> http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2867506&linkID=2475507
> Since you mentioned Civil 3, I'm assuming that you're referring to Civil
> Design 3, and not Civil 3D. Note the version of LDT with the problem in
> the
> above article.
> HTH
> Don Reichle
> "King Of Work-Arounds"
> LDT3 - SP1/CD3 - SP1
> On WIN2K SP4
> Dell 1.6 Ghz P4
> 512MB RAM
> NVIDIA 32MB AGP
> "Neil W" wrote in message news:4216818e_2@newsprd01...
>> I can get the line I want if I add a custom point code to my template at
> the
>> connect point.
