So I have a handful of polygons and all are labeled with a mix of 30, 40, and 60 scale settings using curves and lines, and tagged and regular labels. I then isolate the layer that each loop is on so that I can change all linetypes quickly. When I make the change and unisolate that layer, about 75% of the labels are now N 90-00-00 E at 0.0000' and still associated with the line. I wasn't sure what had caused it the first time, but after I undid a bunch of stuff and then reworked all the labels, checking the labels after each operation, I noticed it was right after changing the loops' layer that it happened. The kicker is that it can't be "Undone". Instead I'm able to use "Swap Label Text" to get the original information.
What I can't grasp is why changing the linetypes made some labels revert to zeroes.
Anybody have any thoughts on that?
Civil 3D 2019 (6.1)
Windows 10 Pro (21H2)
(i7-11850H @ 2.50 GHz)
32GB RAM
NVIDIA RTX A2000
