Bruce,
Using this method, you lose the ability to modify a breakline without
deleting all you breaklines and then redefining them all. If this is the
way you do it, perhaps you would be better off defining them as contours
instead of breaklines. The surface will still be built the same but you
wouldn't have to delete the breaklines from the database first (it lets you
overwrite or append) and you can select them by layer.
Brian
"B Jordan" wrote in message
news:0E7CA938EE16E996596016189DA02704@in.WebX.maYIadrTaRb...
> As far as methods - I have found it easier to keep the originals (don't
have
> LDT erase) and erase the breaklines that LDT does import. This way I
never
> have to worry about overwrite/modify/ignore. I have a set of valid
> 3dpolylines that I can use for breakline data.
> Then if I need to make a change, I delete all the breaklines from the
> surface I am working on, modify my "master" 3dpolyline, then re-create
> breaklines from my "master" 3dpolylines. Again, not erasing my masters,
and
> erasing the breaklines that are imported -
> It's easy enough to delete all, and re-create. With this method I don't
> worry about descriptions because I do not need them.
> Wishlist item, don't assume we want to import our breaklines.
> Bruce
> "Brian Hailey" wrote in message
> news:5D7D8A5FBA858BAF7D321F80CD59F3B1@in.WebX.maYIadrTaRb...
> > I did it again! Anne, if you would. Thank you.
> > John,
> > The way I go about using breaklines is very tedious but seems to work
for
> > me. When I create a breakline from a 3dpoly or other, I'll have LDD
erase
> > the old entity and place the "breakline" in the drawing. Now, if I have
> to
> > modify this breakline, I'll delete it from the database (have it delete
it
> > from the drawing as well to ensure it was deleted), run the add vertices
> > routine (this will strip the breakline data from the entity) using
> something
> > outrageous like 50,000 drawing units, modify the 3dpoly (formerly a
> > breakline) and then redefine it into LDD. If you simply make a small
> tweak
> > to the breakline, you can modify it using any standard editing routine
as
> > long as it doesn't delete the original line and create a new one and
then
> > update the breakline into the database.
> > I hope this helps,
> > Brian
> > "John Mayo" wrote in message
> > news:7067A9DA311B3E685D800116C2E083E0@in.WebX.maYIadrTaRb...
> > > I am creating a surface with 3D polys. I often delete the breakline
mdb
> > def
> > > in the TME. When the breaklines get imported I often have two
identical
> > > 3dpolys over each other. When the TME prompts you that the breakline
has
> a
> > > previous definition I hit the Overwrite All button. Is this correct? I
> > would
> > > hate to explode all of the 3d plines to lines but is there another way
> to
> > > purge the breakline data from a 3dpline?
> > > John Mayo
> > > LDD R3
