You may have already checked this, but if all of your blocks were created
using the same insertion units, (inches, unitless, etc) make sure that under
Format-Units that the 'Drag and Drop Scale' is set accordingly, and also
that under Options-User Preferences the 'Drag and Drop Scale' is the same
there. These may be two ways of accessing the exact same info., but I found
them both, made sure they were what I wanted, and it solved my problem which
sounds pretty similar to yours. Hope it helps.
"LandMan" wrote in message
news:4033f176_3@newsprd01...
> Mine are are either correct or 2x the size depending on what drawing I
> insert into
> "Brian Hailey" wrote in message
> news:4033e086_3@newsprd01...
> > I've been having the same problem. Check the scale and see if it is
1/12
> > (or 12x) what you want it to be. I believe it has something to do with
> one
> > drawing being set up for inches and one for feet but I haven't quite
> figured
> > it out yet.
> > Brian
> > news:4033db87_3@newsprd01...
> > > Different scales. That is why I am wondering is there a drawing
setting
> > that
> > > is having a effect on these blocks.
> > > "Karl Fuls" wrote in message
> > > news:4033d64a$1_2@newsprd01...
> > > > Do they come in at different scales or are they always the same
size,
> > > > regardless of the scale of your drawing?
> > > > I still think Symbol Manager is hard to beat....
> > > > Karl Fuls PLS
> > > > Autocad AEC Training and Consulting
> > > > Assistant Moderator - Autodesk Discussion Groups
> > > > LandMan wrote:
> > > > > Good Day all.
> > > > > Ok this is probably a simple question so please excuse me for
> asking.
> > I
> > > have
> > > > > created a tool palette of blocks. Why do the blocks insert at
> > different
> > > > > scales depending on which drawing I am in. What drawing setting to
I
> > > have to
> > > > > change. Thanks all.
