Show only
Search instead for
I was wondering if there is a way to isolate a block. I have a block that is in a certain layer and I would like to delete all of them. However, when I try to isolate that layer, the blocks get turned off too.
Insert your block and explode it. You will probably find several entities
that are on different layers. Change all entities to Layer "0" (zero) and
re-define it with the same name. You should be able to see your blocks.
"rito" wrote in message
news:21138474.1104343444374.JavaMail.jive@jiveforum1.autodesk.com...
> Hi,
> Thanks!
> Robyn
window all entities on the layer, right click>quick select>block>name> type
the name of your block in the correct spot> enter>delete
Tom
> Hi,
> Thanks!
> Robyn
You could also do a selection set, based on the block filter.
Apply it, then erase previous.
> Hi,
> Thanks!
> Robyn
Use the [Utilities][Create Selection Set] (or SS) to create a selection set
of the blocks.
You can then delete then by typing EP or
EP
Laurie Comerford
www.cadapps.com.au
> Hi,
> Thanks!
> Robyn
