AutoCAD Land Desktop (Read Only)
Autodesk Raster Design 2009 Error
1 REPLY 1
mysticel
2251 Views, 1 Reply
Am using autocad land desktop 2009.  Downloaded the Raster Design OE in order to insert sid files.  When I try to insert sid file I am getting the following errors.  "cannot open frame file:  \AcMapCoordinateTransform.cpp" Line #   "ACMapCorrelation.cpp".  If I ignore the errors the image will insert but not at the correct coordinates.
Any help please....Thanks.....Margie
1 REPLY 1
Darin.Green
in reply to: mysticel
I know this thread is almost a year old, but there's so many people who are still encountering this error message.
To resolve the issue, right-click the application shortcut (located on your desktop) and choose Properties
Navigate to the Compatibility Tab, and check the box "Run this application in compatibility mode for" and choose "Windows NT / Windows ME" from the drop down menu.
If this information was helpful, please consider using the Accept Solution
