AutoCAD Land Desktop (Read Only)
Autodesk Land Desktop 2007
3 REPLIES 3
kellyohern
3366 Views, 3 Replies
In the course of our work we receive dwg files from other companies and 99% of the time we are able to open them and manipulate data for our use, but occassionally when we open a file and try to manipulate data the message, "Autodesk Land Desktop cannot initialize because this drawing contains objects from a newer version", comes up.  We have the senders try to save it in older versions and resend it but we get the same message.  Is there any way of fixing this situation?
3 REPLIES 3
in reply to: kellyohern
Check to see if you have the object enabler program loaded for your version of AutoCAD.  If you don't you can download it from AutoDESK.
   i need to tray Autodesk Land Desktop 2007
lhampton
Download the autodesk "Dwg True View 2012" (here) its a free .dwg viewer that will open and convert most .dwg's to whatever format you want....
Intel i7 2600 /z68 Gigabyte
8gigs DDR3 1800
Intel 320 Series SSD
Quadro 600 (1gig)
C3D 2016 / LDT 2009 / Win7 x64
