AutoCAD Land Desktop
New Member
0 Kudos
Post 1 of 4
Autodesk Land Desktop 2007
1558 Views, 3 Replies
09-07-2011 11:11 AM
In the course of our work we receive dwg files from other companies and 99% of the time we are able to open them and manipulate data for our use, but occassionally when we open a file and try to manipulate data the message, "Autodesk Land Desktop cannot initialize because this drawing contains objects from a newer version", comes up.  We have the senders try to save it in older versions and resend it but we get the same message.  Is there any way of fixing this situation?
33 Kudos
Post 2 of 4
Re: Autodesk Land Desktop 2007
09-07-2011 01:43 PM in reply to: kellyohern
Check to see if you have the object enabler program loaded for your version of AutoCAD.  If you don't you can download it from AutoDESK.
New Member
0 Kudos
Post 3 of 4
03-29-2012 07:59 PM in reply to: kellyohern
   i need to tray Autodesk Land Desktop 2007
Active Contributor
4 Kudos
Post 4 of 4
04-03-2012 12:48 PM in reply to: kellyohern
Download the autodesk "Dwg True View 2012" (here) its a free .dwg viewer that will open and convert most .dwg's to whatever format you want....
Intel i7 2600 /z68 Gigabyte
8gigs DDR3 1800
Intel 320 Series SSD
Quadro 600 (1gig)
C3D 2014 / LDT 2009 / Win7 x64
