AutoCAD Land Desktop (Read Only)
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
AutoCAD Layers to Microstation Levels
1 REPLY 1
jlopez582
631 Views, 1 Reply
I am trying to export my dwg file to a dgn file and have been very succesful except for one thing. I need my autoCAD layers to export as dgn levels WITH specific Level Numbers. The levels are setup up exactly how i want them in my seed file and the layers i am using in my dwg file are set up to match that seed file. Is there a way to designate a number you want associated to a specific level when exporting to dgn? The export function numbers the levels but they are not even close to what I want/have established in the seed file.
1 REPLY 1
in reply to: jlopez582
What settings are you using for your Mapping preview for setup during export?  Or are you using dgnexport to export your drawing to Microstation?
