AutoCAD Land Desktop
New Member
0 Kudos
Post 1 of 4
Autocad land desktop 2008 companion not loading AecCivil menus
1382 Views, 3 Replies
01-12-2009 07:16 PM
I have installed Civil 3D 2009 and it seems to be working. Now after I have done this, I went into my Land Desktop 2008 companion and I get an error as soon as I start the software, right after the command that says: "AutoCad menu Utilities loaded.;
error; Automation Error. No database
It is not initializing all the AecCivil type menus. I can't activate any land or civil commands only Autocad. When I open a drawing and it seems to pull up the correct project with it. But when I try to use a civil command like list points or a bearing of a line it says:
Unknown command "LDD". Press F1 for help.
What has happened?
Please help!
Re: Autocad land desktop 2008 companion not loading AecCivil menus
01-13-2009 08:16 AM in reply to: laura
Some products have to have Repair of Installation
run after a succeeding product is installed.  Go the Control Panel, Add
Remove Programs and run it on your 2008.
Bill
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Utilities loaded.;
database
of a line it says:
help.
What has happened?
Please
help!
New Member
0 Kudos
Post 3 of 4
02-06-2009 01:41 PM in reply to: laura
I am getting the same problems with my LD 2009 menus and commands not working. The menus are showing, but the commands do not work. Also getting error messages that the project folders and databases are missing or corrupted.
I have Civil 3D and LD 2009 installed on my machine for the past four months. LD 2009 has worked during that time, until now. Civil 3D has not been loading the menus/commands at all. AutoCAD commands work just fine.
New Member
0 Kudos
Post 4 of 4
06-05-2012 03:11 PM in reply to: laura
I have exactly the same problem. Can any body help?
