AutoCAD Land Desktop (Read Only)
AutoCad Land Desktop 2007/2008/2009 - Installing Issues
5 REPLIES 5
17556 Views, 5 Replies
Hello Everyone,
I work as an IT for a company doing land surveys where AutoCad Land Desktop is one of our main programs. Previously we were using old outdated systems with a 32 bit operating system. Now after beginning our refresh program we have purchased 64 bit operating systems...
ISSUE:
When trying to install AutoCad Land Desktop 07, 08, or 09; I receive an error message which states the following;
"This is a 32-bit AutoCAD Land Desktop (YEAR). It can not be installed on a 64-bit Windows."
Questions:
Other than purchasing the new software, which is expensive what are my other options? I have heard that you can not run a 64-bit program on a 32-bit system, however there should be no issue when trying to run a 32-bit program on a 64-bit system. Can I get a 64-bit version somewhere and install it using our activation keys? Could autodesk provide me a software download to do so? Are there any hotfixes or work arounds for this issue?
Thank you all for your time and help.
Andrew
5 REPLIES 5
My understanding is that you need Win 7 64 Pro or Ultimate because it has XP emulation.  The LDC 07-09 series can be installed with the XP emulation.
There are no 64 bit versions of these programs.  Civil 3d 2011 is the only 64 bit product, and there is no LDC after C3d 2009.
Reid
duongthieu.ddt
This is Civil 3D Land desktop Companion 2009 64bit version.
If you can't use LDT 2007 on 64bit OS, this is the best solution. Every thing in LDT 2009 is look like 2007 version!
Link download under Video (Free and No survey): https://www.youtube.com/watch?v=9xUoq0SdwBg
duongthieu.ddt
You don’t have to use Longbow software or setup vitual
Land desktop companion 2009 is the best solution on win 64 bit.
Every funtions, display, commands in land desktop civil design 2007 is all in LDT 2009
You can see and download here!
