I am using AutoCad Land Desktop 2009, and recently AutoCAD does not prompt the AutoCAD Alert when two people are working on the same file, and as you can imagine it has become a bit of a headache after changes have been made to a read-only file. Where can I go to check the setting for this AutoCAD alert to make sure it prompts when someone else is using the same file?
