AutoCAD Land Desktop (Read Only)
?? ARX_ERROR: eNotThatKindOfClass ??
5 REPLIES 5
941 Views, 5 Replies
Does anyone know what this means, and how to fix it?
This one drawing has been giving me a lot of grief.
It hapens in Map, as well as LDT, but not in 2002 with SurvCADD.
What is it??
Jeff Clark
Designer III
Consulting Engineer Services
Sewell, NJ
Acad 2006 LDT w/CD
5 REPLIES 5
This typically shows up when you recieve a drawing from someone else using
Architectural Desktop. I'm pretty sure if you WBLOCK the drawing out, and
tell it not to export the Land Desktop data, it'll strip out the Arch.
Desktop references, and eliminate the errors. HTH An audit and purge
before hand would probably help, as well.
Dennis Hyman (aspiring PLS)
Cad Tech. - Survey Dept.
Stock & Associates Consulting Engineers
Chesterfield, Missouri
LDD 2004, Civil, Survey, Map
2.4 Ghz P4, 512 MB RAM
GeForce 4 MX 440 Graphics Card
"Jeff Clark" wrote in message
news:5623462@discussion.autodesk.com...
What is it??
Jeff Clark
Designer III
Sewell, NJ
Acad 2006 LDT w/CD
There is a hotfix for that available at the knowledge base.
Joe
Joseph D. Bouza, EIT
Win XP pro
v 2002, sp 2
hp workstation xw4100
In memory of the King of Work-arounds
"The only Constant is Change".
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
"Dennis Hyman" wrote in message
news:5623505@discussion.autodesk.com...
What is it??
Jeff Clark
Designer III
Sewell, NJ
Acad 2006 LDT w/CD
Joe, the Hot Fix worked perfectly.
Thanks, and I'll bookmark the Hot Fix search page.
Jeff
"Joe Bouza" wrote in message
news:5623509@discussion.autodesk.com...
Joe
Win XP pro
v 2002, sp 2
What is it??
Jeff Clark
Designer III
Sewell, NJ
Acad 2006 LDT w/CD
HTH
Win XP pro
v 2002, sp 2
news:5623554@discussion.autodesk.com...
Jeff
Joe
Win XP pro
v 2002, sp 2
What is it??
Jeff Clark
Designer III
Sewell, NJ
Acad 2006 LDT w/CD
I understand from previous correspondence there is a "hotfix" for this but how do I download it and use it.............?
Don Evans
