I would have to disagree. I use those commands all day long, but if I had to
take a 500 acre irregular shaped tract and cut it up into 5 acre lots it
would take a very long time using just plain AutoCAD commands. I would have
to draw, check area, adjust, check area, adjust, check area, draw, check
area, etc, etc. Parcel commands do save time, but it could be much better.
Doug
"wfb" wrote in message
news:4107d7d4$1_2@newsprd01...
> "Doug N" wrote in message
> news:4107bc77_1@newsprd01...
> | I use ldd4 (have ldd5, but not installed yet). Ldd4 has "parcels" for
> | creating lots, but it seems extremely limited. Is there any subdivision
or
> | lot
> | creation cad software available that would work within the autocad
> | environment? It would be nice to select lines or curves to divide up a
> | parcel, instead of having to go from point-to-point-to-point-to-point.
> Use regular old AutoCad commands, offset, extend, fillet & etc. There is
> nothing sacred about using Parcel commands, they are not necessary!
> | Let me try to give an example. Lets say you have a "D" shaped parcel
that
> | contains 20 acres (871200 sq ft) and you want to split it up into 4-5
acre
> | (217800 sq ft) Lots. The top and bottom of the "D" are N 90deg E and the
> | west line of the "D" is N 00deg E. I want the lots to go from North to
> | South with the front of the lots on the arc of the "D". The lot lines
> will
> | have a bearing of N 90deg E.
> | I want to use "slide bearing". Once I have selected it, its asks for
> "parcel
> | first point" (no option for lines/curves).
> | I'll start at the S.W. corner of the "D", I have selected my first point
> it
> | asks for "next point (or curve)".
> | I choose to select the S.E. corner of the "D" and its asks again ""next
> | point (or curve)".
> | Now I could type "c" for curve and select the curve, then select a
point
> on
> | a curve, then select the end point of the curve, then tell it if it is
> | inside or outside, but this is only if I wanted to go around the "D". I
> | want to devide up the "D" along the arc, so I hit enter after my last
> | selection it asks for a "first direction", I select a point on the West
> side
> | of the "D" and hit enter.
> | It then asks for "second direction", Now what do I do? I don't have the
> | option to select the arc. I can only select a point.
> | Thanks,
> | Doug
