AutoCAD Land Desktop (Read Only)
add vertices to viewport
5 REPLIES 5
cgib
67869 Views, 5 Replies
Is there any way to add vertices to your viewport?
5 REPLIES 5
pitfool
in reply to: cgib
vpclip might do what you are looking for. You can increase or decrease the area of the viewport with this command. However, when you create the viewport (MVIEW or MV), you have the option of creating a polygonal viewport. Hope this helps.
in reply to: cgib
If you create polygonal viewports or convert objects to a viewport, you can use the standard pedit on them and then V for vertices and then I for insert. It works but you have to have created the viewport by one of the previous two methods. It won't work on a regular rectangular viewport. I convert all mine from a rectangle and that way if I want to add vertices later it will work.
in reply to: cgib
And a very well-planned scheme for future needs - whether they appear or
not. 🙂
Don Reichle
"King Of Work-Arounds"
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT-2K4
AMD64 3200+
XPPro 32bit SP2
1GB RAM
Nvidia GeForce FX 5200 128MB
Western Digital Raptor 10K-rpm HD
wrote in message news:4968575@discussion.autodesk.com...
later it will work.
Justin_A
in reply to: cgib
Awesome! VPCLIP worked perfectly for me you just have to draw the desired outline of the VP.
kishorereddy
in reply to: cgib
Dear Friend....
 we can show horiz. plane drawing in model space to vertical plane in paper space..
MV    -   Enter
Draw a window and double click in that window and thenchange UCS-in Z-Axis to 90 then
go to VIEW-3Dview-plan view-current UCS  that's it.
i hope it will helps UUUUU...
Regards
Gkkreddy Smiley Happy
