AutoCAD Land Desktop (Read Only)
AcRxDynamicLinker failed to load ... AecclB.dbx
3 REPLIES 3
enconwjc
688 Views, 3 Replies
I had to uninstall my LDD 2i and re-install, and now I get the following error during program startup and my Projects menu does not install (HELP) :
"Regenerating model.
Initializing....
.Done.
AutoCAD Express Tools Copyright © 2000 Autodesk, Inc.
AutoCAD menu utilities loaded.
Loading AecBase...
Loading AecUiBase...
Loading AecUtilities...
Loading AecCivilBase...Error code (0x2) The system cannot find the file
specified.
AcRxDynamicLinker failed to load 'C:\Program Files\Common Files\Autodesk
Shared\AecclB.dbx'
C:\Program Files\Land Desktop R2\acad.exe
Required application "AecCivilBase" not loaded.; error: ARXLOAD failed
Command:"
3 REPLIES 3
in reply to: enconwjc
enconwjc the only thing I could find in a Search of the Knowledge Base using
"AcRxDynamicLinker failed to load" - w/o quotes - was this in the following
tinyurl:
http://tinyurl.com/ysbt52
So since that mentions Mechanical Desktop, I then used "Loading
AecCivilBase...Error code (0x2)" - again w/o quotes - in my next Search of
the Knowledge Base. It didn't find any results, as you'll see in the
following tinyurl:
http://tinyurl.com/28zo5j
Do you have any other AutoCAD products on your PC, before we go any further?
And... have you been in touch with a local reseller regarding your situation
as of yet?
I'm sorry I didn't look at your Subject earlier today. 😞
I had a fairly miserable experience with LDT 2Ki back in 2003. After
speaking with the firm's reseller CAD Masters in the SF Bay area for a
couple of days, we determined that I was only likely to reach completion if
I would format the PC's hard drive, and then reload every application from
"scratch" as it were.
That worked, as was hoped by us all. But it did require about 3/4's of a day
to accomplish. 😞
Not what you were hoping to hear, I'm thinking.
Please let us know how things turn out.
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5569042@discussion.autodesk.com...
Initializing....
.Done.
Loading AecBase...
specified.
Shared\AecclB.dbx'
Command:"
enconwjc
"Do you have any other AutoCAD products on your PC, before we go any further?"
I had Acad R14 and Softdesk on but have removed them.
I also had a few addons like MColor, a pdf maker, and extra toolbar stuff - all removed.
I have not been in touch with my local reseller, and come to think of it, I havent talked to them in about 6 years (since install). -> I have a call in to them now and will let you know of any progress.
"format the PC's hard drive" <- unacceptable. There must be another solution.
-Bill Message was edited by: enconwjc
enconwjc
Just to update everyone (as I know you are all sitting on the edge of your seats) ... I ran a registry cleanup program after I uninstalled Acad and viola -> works like new. so go to your favorite search engine and type in registry cleaner. run (usually free trial) and clean up your registry.
Bill
