AutoCAD Land Desktop (Read Only)
Acadobjects from Alignments
3 REPLIES 3
192 Views, 3 Replies
In VBA:
If I isolate the elements of an alignment, and set a variable to the element ( Say: Tangent = the element which is ktangent), can I then create a new variable for an Acadentity or Acadobject and set that variable equal to the tangent? I assume a tangent is basically an AutoCad line. I have tried with no luck, and was hoping that someone could point me in the right direction. Hope I was clear with my question.
Regards
Rob
3 REPLIES 3
Rob,
Use the AddLine method to create the line using the
coordinates from the alignment tangent.
Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint,
endPoint)
Before creating the line you should use the
AeccUtility method EastNorthToXy to convert the northing easting coordinates to
X,Y for the current drawing. This takes into account the drawing base point and
rotation.
The Land ActiveX Reference help file
has an example on using this method.
Glen
In
VBA:
Regards
Rob
Hi Bob,
The tangent can be drawn as a line with appropriate code, but in the VBA
environment it is not a line, but an aeccobject.
Unless you let us know precisely what you want as output it's hard to go
further.
Laurie Comerford
CADApps
www.cadapps.com.au
"DingDong" wrote in message
news:f0ca8e2.-1@WebX.maYIadrTaRb...
> In VBA:
> Regards
> Rob
Thanks for the responses….
I think Glen has outlined what I should do, but to answer Laurie’s question, I am trying to locate the intersection of all alignments that either cross each other or start/end on other alignments. I know that a method exists to determine the intersection of a line with an alignment, but I think that method uses 2 points to project a line until it intersects the alignment. What I want to do is use the Acad method to list all intersections that actually exist, without projecting the line. That is why I wanted to convert the Ktangent to a line and Kcurve to an arc.
Thanks again!!!
Rob
